2004 BMW 325 Wont Turn over
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSH BUTLER
I changed the fuel filter and the fuel pump relay and still can't get it to turn over. It is trying to crank but just won't turn over. The problem started when I was driving the car and it started stalling then finally just cut off. And it would not turn over after that. So my first thought was the fuel filter so i replaced it then that did not work so I changed the fuel pump relay. Can you give me any suggestions that would be great.
Oct 1, 2009 at 7:08 AM
DOCHAGERTY
  • 9,606 POSTS
Check the fuel pump, it is on the right side of the car under the rear seat.
Oct 4, 2009 at 4:41 AM
