2004 BMW 325 won't start
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
PONGMAN
car has been in the garage for 2 weeks, it cranks good but won't fire. Nevr a problem before. Its like someone pulled the coil wire.
Nov 30, 2008 at 12:23 PM
DOCHAGERTY
  • 9,606 POSTS
There are three things needed to make an engine run, spark, fuel and compression. We can probably rule out compression and that leaves fuel and spark. Is there good fuel in it? Is it getting fuel? Try spraying brake clean into the intake and see if it starts. If no joy then repost and we will keep going. Keep in touch!
Nov 30, 2008 at 12:46 PM
