2004 BMW 325 vibrating when stopped
56,000 MILES • 6 CYL • AWD • AUTOMATIC
THIAGUY
When im stopped at light,sign,etc.,my steering wheel starts to shake and engine seems louder. Any ideas? Thanks.
Mar 27, 2009 at 7:33 AM
DOCHAGERTY
  • 9,606 POSTS
Is the check engine light on?
Mar 27, 2009 at 8:33 AM
THIAGUY
no,my service engine light isn't on. thanks so much for the reply.
Mar 28, 2009 at 11:29 AM
JAMES W.
  • 2,394 POSTS
If you let up on the brake does the shaking in the steering wheel stop??
Mar 28, 2009 at 5:58 PM
THIAGUY
Sorry for late reply(internet problems). Everything sounds and feels normal after stepping off the brake. There is one thing that happened this week, the engine made the same sound that Im discribing when I was parked and I turnd on my foglights. Weird! Thanks
Apr 3, 2009 at 11:58 PM
JAMES W.
  • 2,394 POSTS
It sounds like your idle speed control system is failing and won't compensate for added engine load. Does it act the same when you turn the AC on high?
Apr 4, 2009 at 5:52 AM
THIAGUY
Yes, thats exactly what it acts and sounds like. Is this something that I can take care of myself and is it something I should address right away? Thanks
Apr 4, 2009 at 1:09 PM
JAMES W.
  • 2,394 POSTS
The IAC is a small motorized unit that is mounted either on thr intake manifold by the fuel injectors or on the throttle body. It may just have to be removed and cleaned. It will have 3 wires going to it.
1-wht / grn
1-red / yell
1-wht / yell.
Apr 4, 2009 at 3:44 PM
DOCHAGERTY
  • 9,606 POSTS
The idle speed can be increased electronically through the GT-1 unit that the dealer and some independents have, call around.
Apr 5, 2009 at 3:01 PM
