2004 BMW 325 Start Problem
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
VGANJI
I have a 2004 BMW 325i which when I tried to start it makes clicking sound but does not start. The battery seems fine (lights are working). I would like to be able to start it to take to a mechanic. Thank you for your help.
Oct 8, 2009 at 11:46 AM
DOCHAGERTY
  • 9,606 POSTS
The battery is most likely low and will require charging or perhaps replacement, AVOID jump starting the car. Check battery voltage with a digital volt/ohm meter, it should read above 12.5 volts at rest.
Oct 8, 2009 at 4:29 PM
