2004 BMW 325 Rhumbling down the road
DML7363
Drive Train Axles Bearings problem
2004 BMW 325 6 cyl Two Wheel Drive Automatic 46k miles
2004-325i, 46K miles: have a rhumbling as we roll, sounds like bearings. Lifted the front, they sound fine, slight disc rubbing. Rear, in neutral, seem to click, not clunk. Saw bearings on autowarehouse, one with a housing and the other with just a bearing. What else can I do before I replace the bearing? Also, with the hub or single bearing. Thanks, Doug in Miss.
Jun 23, 2008 at 1:47 PM
DOCHAGERTY
  • 9,606 POSTS
Doug, this takes some special tools. You might be able to do it but the tools cost about $300 and you might be better off having a trained BMW professional perform the repairs.
Jun 23, 2008 at 4:17 PM
