2004 BMW 325 REPLACED STARTER
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
WHITERA01
  • 6 POSTS
I replaced the starter in my 04 bmw 325 ci and it turns over but will not start. I think it has to do with the alarm in it but have no idea how to reset it
Aug 27, 2010 at 3:51 PM
DOCHAGERTY
  • 9,606 POSTS
The problem might be the alarm, is it the stock BMW alarm?
Aug 27, 2010 at 4:16 PM
WHITERA01
  • 6 POSTS
i believe it is the factory alarm
Aug 27, 2010 at 4:24 PM
DOCHAGERTY
  • 9,606 POSTS
Try disconnecting the alarm module. It is in the wiper tub, removal of the pollen filter housing and the firewall cover is first. http://www.realoem.com/bmw/showparts.do?model=ET37&mospid=47720&btnr=64_0847&hg=64&fg=10
It will require a T-30 Torx driver.
Aug 27, 2010 at 4:37 PM
WHITERA01
  • 6 POSTS
are there any other ideas just in case what about a system reset from the key
Aug 27, 2010 at 4:43 PM
DOCHAGERTY
  • 9,606 POSTS
Turning the key to the run position is the reset for the factory alarm. The crank no start condition is not usually associated with EWS, it will deactivate the starter and the fuel injection and the ignition. Having said that, I would perform a scan of the car with the proprietary BMW software to uncover faults (if any) Simply replacing a starter does not seem to have these implications, it almost seems there is some other issue at play here. EWS is the drive away protection, it is separate from the car alarm, it reads the chip in the key and then a "handshake" is performed, when this is satisfied, the DME allows the starter to engage, fuel and spark to occur. All BMW cars in the 2004 model year have this, the car alarm does not come as standard equipment, it is prewired for it but it has to be installed and coded to the car.
Aug 28, 2010 at 2:16 AM
WHITERA01
  • 6 POSTS
hey i put a scanner on my bmw and these pending codes came up #p1413 p1430 manufacturer specific codes and p2401 evaporative emission leak detected and evaporative emission control switching valve any ideas?
Thank you for your help
Aug 28, 2010 at 1:11 PM
DOCHAGERTY
  • 9,606 POSTS
https://www.2carpros.com/kpages/diagnostic_trouble_codes.htm
The DMTL codes are possibly a loose fuel cap and/or a tank vent valve issue.
Generic fault codes are captured in the link above.
Aug 28, 2010 at 3:50 PM
WHITERA01
  • 6 POSTS
Thank you for the code info. I tried to located the alarm module with no success i'm unsure of what it looks like will it have any markings on it to help identify it?
Aug 28, 2010 at 4:02 PM
DOCHAGERTY
  • 9,606 POSTS
65758383152 #4 in this link: http://www.realoem.com/bmw/showparts.do?model=EV53&mospid=47725&btnr=65_0486&hg=65&fg=60
This is what it looks like, #4. It is in the area behind the pollen filter/fire wall cover, it takes a T30 Torx driver.
Aug 28, 2010 at 4:12 PM
WHITERA01
  • 6 POSTS
Thank you so much i really appreciate all the info you have given me
Aug 28, 2010 at 4:17 PM
DOCHAGERTY
  • 9,606 POSTS
Pretty cool link too!
Aug 28, 2010 at 4:21 PM
