2004 BMW 325 Power steering fluid
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
GARY HOBSON
I went to a lube place to get a lof and after a few miles my steering got real hard . so i ckecked things out and i found they fill the resivoir with oil i need to drain and flush it. how do i do this
Apr 29, 2009 at 5:25 AM
DOCHAGERTY
  • 9,606 POSTS
A turkey baster or some way to suck the oil out of the reservoir might work. The banjo bolt fitting at the P/S pump could be loosened to facilitate this process. Refill with Dexron ATF.
Apr 30, 2009 at 4:12 AM
