2004 BMW 325 Driver door
NIKOLAI BARAN
Interior problem
2004 BMW 325 4 cyl Front Wheel Drive Automatic
The Chesk Door untired from the door side and some part got inside the door and fix the window. Could you explain me how to remove the innner panel of the door to get access inside the door. Thank you in advanc[img:69ae4b429c]http://www.2carpros.com/forum/automotive_pictures/482580_Resize_of_P1110002_1.jpg[/img:69ae4b429c]e.
Feb 14, 2010 at 7:13 AM
DOCHAGERTY
  • 9,606 POSTS
Remove the trim strip and then the screws behind it, the SRS button has a screw behind it, a plastic wedge tool will then pop the panel off.
Feb 14, 2010 at 5:46 PM
