2004 BMW 325 Crunch noise as window goes down or up on 325I
2004 BMW 325
SHKDVR9996
Noises problem
2004 BMW 325 6 cyl 77000 miles
My 325I passenger window was going down today and made a crunching noise when getting near the end to being down. The rear side of the window was still showing about 1/8". When I put the window up I think it is off the track. There are plastic pcs that hold the window I think? I have replaced window regulators on my other cars and they were missing a tooth. What do you think about this? My other question is what precautions to take if I try to diognose by removing the door panel since there is a side airbag in there.
Appreciate any help you can give!
Billy
Apr 26, 2009 at 12:20 PM
DOCHAGERTY
  • 9,606 POSTS
The window regulators are making the noise. The attach point to the cable on one of the sliders has lost its integrity and the window is screeching/crunching due to the glass against the "U" channel track. When performing these repairs, disconnect the battery so the airbag system wont log a fault and you dont need to remove the airbags from the wiring connector, just hold them out of the way and you wont risk damaging the connector, it is how I do it.
Apr 27, 2009 at 1:04 AM
