2004 BMW 325 cooling system
MHOOK
Engine Cooling problem
2004 BMW 325 6 cyl Two Wheel Drive Automatic
Recently the car overheated.I check the system out and notice there is a leak on the expansion tank. What can cause the expansion tank to leak? Is there any way to check if there i any damage to the engine?
Apr 11, 2010 at 8:59 AM
DOCHAGERTY
  • 9,606 POSTS
Plastic tank, cracks when it is hot and cold several hundred times, also called thermal cycling. Damage? I dont know. Did you drive it in the red?
Apr 11, 2010 at 12:43 PM
MHOOK
[quote:9bf331f6f7="Dr. Hagerty"]Plastic tank, cracks when it is hot and cold several hundred times, also called thermal cycling. Damage? I dont know. Did you drive it in the red?[/quote:9bf331f6f7]
No luckly i made it to my destination b4 it go to the red mark.
Apr 11, 2010 at 2:48 PM
