2004 BMW 325 2004 BMW Spark Plugs
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
BREWFAN
I've looked everywhere and can't find the plugs on my car. I'd really like to check them before spending $300 on a new fuel pump.
Mar 18, 2010 at 10:43 AM
DOCHAGERTY
  • 9,606 POSTS
The plugs are under the cover that says BMW on top of the motor, you will need to remove the coils as well. What does spark plugs and a fuel pump have to do with each other? If the fuel pump is bad, looking at the plugs aint gonna change that.
Mar 18, 2010 at 3:54 PM
BREWFAN
The car started sputtering and then died, now it won't fire at all. I checked the valve on the injector bar and it's releasing a small amount of air but no gas, which makes me believe it's the fuel pump. But, I'd like to check the plugs just to eliminate them.
Is this logic wrong?
Thank You for your help!
Mar 19, 2010 at 4:19 AM
