2003 BMW 325 Struts
47,000 MILES • 6 CYL • 2WD • AUTOMATIC
JPPJ36
  • 8 POSTS
I just took my car in for inspection at the local mechanic. They noted that I should replace the front struts and rear shocks because they were leaking. He showed me that there was a small amount of fluid on one of the front struts. Isnt a small amount of oil normal? Is it absolutely necessary to replace? There is no noticible problem while driving. Thank you. P.S. It did pass inspection.
Aug 28, 2008 at 1:54 AM
DOCHAGERTY
  • 9,606 POSTS
At 47K miles I would not worry too much. And you state the car is handling okay and you dont feel it is a safety issue, so I would ignore the recommendation and drive the car♥
Aug 28, 2008 at 2:23 PM
