2003 BMW 325 fuel
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
CDSUTTON
My car gas line was on the red line. I went to the gas station and filled the car up completely. I drove from the gas station to the store which is in the same parking lot. Went inside for groceries about 1-2 hours. I put my groceries in my car and then attempted to start the car. the car cranked but would not turn over. It was as if gas was not reaching. I pressed the gas peddle but nothing. All the lights were working fine. The oil is fine. But the car would not start up. It wanted to start but just didn't. I went back in the store and bought some Lucas and it did nothing. I thought maybe it was a fuse but am not aware which fuse it is. Can you please help me?
Nov 20, 2009 at 2:40 PM
CDSUTTON
[quote:c1d8341a9d="cdsutton"]Engine Performance problem
2003 BMW 325 6 cyl Four Wheel Drive Automatic 100000 miles
My car gas line was on the red line. I went to the gas station and filled the car up completely. I drove from the gas station to the store which is in the same parking lot. Went inside for groceries about 1-2 hours. I put my groceries in my car and then attempted to start the car. the car cranked but would not turn over. It was as if gas was not reaching. I pressed the gas peddle but nothing. All the lights were working fine. The oil is fine. But the car would not start up. It wanted to start but just didn't. I went back in the store and bought some Lucas and it did nothing. I thought maybe it was a fuse but am not aware which fuse it is. Can you please help me?[/quote:c1d8341a9d]
Nov 20, 2009 at 3:30 PM
DOCHAGERTY
  • 9,606 POSTS
Is there proper fuel pressure? Have you got a mechanic? I wont be able to do much from cyberspace with what I have to work with here.
Nov 21, 2009 at 1:01 AM
