2003 BMW 325 Engine Temp
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOSINGH
engine temperature is normal when idol however when driving temperature falls signficatly
Jan 15, 2008 at 10:06 AM
MASTERTECHTIM
  • 4,750 POSTS
you have a bad thermostat. it is always open. very common. i just bought one from dealer. cost is about $80. it comes with the housing and the cooling temp sensor. hope this helps.
Jan 15, 2008 at 10:09 AM
MOSINGH
sounds good. how difficult is it to change this?
Jan 15, 2008 at 10:13 AM
MASTERTECHTIM
  • 4,750 POSTS
if your mechanically inclined, you can handle it. you dont need any special tools.
Jan 15, 2008 at 10:44 AM
MOSINGH
where is the thermostat on the BMW located?
Jan 23, 2008 at 8:23 AM
MASTERTECHTIM
  • 4,750 POSTS
the upper rad hose connects to it, on the engine. it comes as an assembly, the whole housing with the sensor on top of it. it costs about 80 from bmw.
Jan 23, 2008 at 10:41 PM
MOSINGH
is there an easy way to get the engine fan off?
Jan 24, 2008 at 8:19 AM
DOCHAGERTY
  • 9,606 POSTS
It requires special tools. it takes a 36MM end wrench and a holding tool for the pump pulley. You might be able to get it off with a 36MM wrench and a couple of sharp whacks with a hammer to shock it loose. It is left hand thread BTW.
Jan 24, 2008 at 10:13 AM
