2003 BMW 325 CV Boot Replacement
79,000 MILES • 6 CYL • AWD • AUTOMATIC
JBAKIN
I have removed the tire, brakes, roter and my instruction manual says to remove the driveaxle first so I removed the driveshaft nut and next it says to remove the bolts securing the driveaxle constant velocity joint to the differential unit however, I can't find any bolts to remove.
After removing the driveshaft nut should the driveshaft come off? If so, how does it come off?
Where do I find the bults securing the driveaxle cv joint?
At the moment I fell as thou I am in a little over my head but I'm hoping you can help me out!!
Dec 27, 2007 at 9:53 AM
MERLIN2021
  • 17,250 POSTS
The bolts are on the other end, on the inboard joint...remove them and then pull the shaft down and out.
Dec 27, 2007 at 9:56 AM
JBAKIN
[quote:de41fe0a5c="merlin2021"]The bolts are on the other end, on the inboard joint...remove them and then pull the shaft down and out.[/quote:de41fe0a5c]
I looked on the inner joint but didn't see any bolts there either? Do I have to take off the inner CV boot to find the bolts?
Dec 27, 2007 at 10:34 AM
