2003 BMW 325 Check Engine Light
41,000 MILES • 6 CYL • 2WD • AUTOMATIC
JPPJ36
  • 8 POSTS
My check engine light came on and the O2 after cat sensor was replaced. A week later the light came on when I started the engine on a 10 degree day. I heard a noticible ping in the engine as I turned the ignition then the light came on instantaneously. The error code was P1418. Local mechanic wasnt sure but changed a small airflow hose that was brittle. Any idea what the ping was. Thanks
Jan 16, 2008 at 1:45 AM
DOCHAGERTY
  • 9,606 POSTS
You have me at a disadvantage as I cant hear the noise from cyberspace. if it was a one time occurance I would not be alarmed.
Jan 24, 2008 at 10:39 AM
