1985 BMW 325 no check engine light on
LLOYDEE
  • 1985 BMW 325
  • 6 CYL
  • MANUAL
  • 94,842 MILES
Without the ckeck engine on.I have no power to the distribitor nor do my fuel pump come on. So what do I do to correct this problem.
Thursday, March 12th, 2009 AT 9:11 PM
LLOYDEE
Thursday, March 12th, 2009 AT 9:14 PM
LLOYDEE
BUY A REPAIRE MANUAL.I COULD HAVE DONE THAT, BUT WAS LOOKING FOR A FAST ANSWER I DONT THINK YOU ANSWER WAS WORTH MY 15.00 DOLLARS. BUY A REPAIR MANUAL. YOU GOT TO BE JOKING 15.00 TO TELL ME THAT. VERY UNHAPPY WITH YOUR ANSWER.
Thursday, March 12th, 2009 AT 9:56 PM
DOCHAGERTY
  • 9,601 POSTS
Check the fuses and inspect/replace the main and fuel pump relays and see if there is power from the battery to these relays.
Thursday, March 12th, 2009 AT 9:57 PM
LLOYDEE
THANKS FOR YOU REPLY. THAT WAS BETTER THAN THE FRIST REPLY[BUY A REPAIR MANUAL] KNOW ONE MORE QUESTION. WHERE WOULD I START TO FINE THAT MAIN ENGINE RELAY.
Thursday, March 12th, 2009 AT 10:04 PM
DOCHAGERTY
  • 9,601 POSTS
It is located next to the fuse box. The main relay is probably a metal case(as opposed to a plastic case for replacement relays) and is about 30mm x 30mm square. The fuel pump has a green wire with a purple stripe coming from terminal 87.
Thursday, March 12th, 2009 AT 10:21 PM
