2003 BMW 325 ac blowing the ac fuse
106,526 MILES • 6 CYL • 2WD • AUTOMATIC
STARSKY12421
ac fuse keeps burning after 10 min of replacing
Aug 8, 2009 at 11:32 AM
DOCHAGERTY
  • 9,606 POSTS
What # is the fuse and what is the capacity of the fuse?
Aug 9, 2009 at 5:12 AM
STARSKY12421
It is the # 5 fuse and it is in slot 28 there three fusses for the ac but that one is the only one burning out
Aug 9, 2009 at 6:53 AM
DOCHAGERTY
  • 9,606 POSTS
So its a 5 amp fuse in #28, is that correct?
Aug 10, 2009 at 7:28 AM
PROFESSORHEADY
Yes, it's the 5 amp, # 28 fuse. I am having the same problem as stated by the person before. Mine will run fine for 20 minutes, but as soon as I start to drive the car and hit the slightest bump, the fuse blows again. I've tried taking the AC Headunit out and making sure all the connections were snug, and no wires were stripped of their casing etc. Any idea's?
Sep 28, 2009 at 10:05 PM
DOCHAGERTY
  • 9,606 POSTS
This could be the head unit itself, measure the current flow at rest and if > 4 amps, replace the head unit.
Sep 29, 2009 at 2:12 PM
