HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
BMW
325
Climate Control
Heater
Not Working
2003 BMW 325
POPE0814
MEMBER
2003 BMW 325
4 CYL
2WD
AUTOMATIC
130,000 MILES
My heater is not working. Any suggestions?
Saturday, January 9th, 2010 AT 8:35 PM
DOCHAGERTY
MECHANIC
Perhaps a stuck heater valve. Disconnect the wiring connector at the heater valve and see if you get heat, the valve is commanded closed, removing power should let heat flow.
SPONSORED LINKS
Saturday, January 9th, 2010 AT 9:59 PM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
2006 Bmw 325 Fan Running Very Loud When Heater Is On...
I Noticed My Fan Was Making A Loud Noise When My Heater Is On. It Gets Really Loud And Goes Up Than Down And Up And Down. Sometimes It Won't...
Asked by
ashall29
2006
BMW 325
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
2001 Bmw 325 Fan Issue
Heater Problem 2001 Bmw 325 Automatic Hi I Have A 2001 Bmw 325i Which Is Having Some Fan Issue. When I Start The Car The Fan...
Asked by
keesan
2001
BMW 325
Heater
Gentlemen, I Have A 1993 325i With Rebuilt M50 Engine. Approx 550 Miles On A Automatic Trans. Engine Is Running On Correct Temp But No...
Asked by
bernie teng
BMW 325
1995 Bmw 325 No Power To Heater Control Valve
Hi Felllas:) I Am Having Issues With My Heater. I Was Having Issues With No Heat. Changed Termostast Then A Buddy Said It Could Be A...
Asked by
stumptown503
1995
BMW 325
1990 Bmw 325 Blower Motor
Electrical Problem 1990 Bmw 325 6 Cyl Two Wheel Drive Manual Can I Access The Blower Motor From The Engine Compartment Or Do I Have...
Asked by
captnmel
1990
BMW 325
VIEW MORE
SPONSORED LINKS
Heater Not Working
Blend Door Actuator Replacement
How to Replace Damper Door Switch
Online car repair manuals
