2002 BMW 325 Will not turn over
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
REKOTGNOB
I was driving my car, went home, and came back out the next morning and it would not start. It will crank but not turn over, as if it is not recieving any spark or push to turn over. Could it be that a wire is loose, or more likely that it is a distributor problem?
May 27, 2008 at 4:06 AM
DOCHAGERTY
  • 9,606 POSTS
Possibly the fuel pump took a s***. Try spraying carb cleaner into the intake and if it starts then replace the fuel pump and filter and fuel pump relay.
May 27, 2008 at 1:00 PM
