2002 BMW 325 Signal
2002 BMW 325
MKC34
Electrical problem
2002 BMW 325 6 cyl Two Wheel Drive Manual 74k miles
My right front running light/turn signal is not working all of the sudden. When I put the right signal on, the dashboard light flashes very quickly with no signal from the light on the outside of the car. The left signal continues to work just fine. Both fog lights and headlights are also working just fine. I assume this is an easy fix. Any suggestions?
Oct 29, 2009 at 2:31 AM
DOCHAGERTY
  • 9,606 POSTS
Try replacement of the bulb and an inspection of the bulb holder to start with. You will need to remove the turn signal assembly to do this.
Oct 29, 2009 at 4:19 PM
