2002 BMW 325 Rear window register
SQRLSNESTX4
Interior problem
2002 BMW 325
I need a little help I got the register out of the mount holes. But how do I remove the register from the window?
Jul 15, 2009 at 11:21 AM
DOCHAGERTY
  • 9,606 POSTS
The register? What part is that? Do you have a part number?
Jul 16, 2009 at 2:11 PM
SQRLSNESTX4
The part number for the register is B491707 the discription in the parts catalog is a regulator.
Jul 19, 2009 at 1:25 PM
DOCHAGERTY
  • 9,606 POSTS
The black plastic trim piece on the inside, between the door glass and the quarter glass gets pried off and the screws behind it removed. Then pull the channel felt out of the slide with the window down and the glass should come out so you can access the top mount bolt for the regulator which will be a Torx bolt.
Jul 21, 2009 at 1:11 PM
SQRLSNESTX4
Thanks for your help I will try that when I get home.
Jul 21, 2009 at 11:02 PM
