2002 BMW 325 Engine mounts
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
MERBIMER
Hi-
Can u give me some directions in how to replace the engine mounts ?
Dec 22, 2009 at 3:47 AM
2 CARVINCE
  • 31 POSTS
To replace front engine mounts you must first have the correct one's in hand , there is a left and right and they don't interchange, ,Then you must unbolt the mount on top , Then place a floor jack under oil pan, jack engine up slowly remember top bolts on mount have been removed first ,then rise engine up slowly to lear bolt then unbolt bottom . Reverse instructions to install .
Jan 11, 2010 at 5:47 AM
