2002 BMW 325 Clutch clank
2002 BMW 325
60,000 MILES • 4 CYL • 2WD • MANUAL
DFDORAMA
When I fully depress the clutch on my 325i 5 speed, it makes a clanking noise that varies with the speed of the drive shaft. Happens whenever the clutch is fully depressed. If I depress only a bit less, I can shift fine without the noise. Transmission otherwise seems fine.
Feb 9, 2009 at 8:43 AM
2CARPRO JACK
  • 11,533 POSTS
I have forwarded your link to our resident BMW expert. He should be with you shortly
Thanks for using 2CarPros.com
Feb 9, 2009 at 11:28 AM
DOCHAGERTY
  • 9,606 POSTS
Thanks Jack. Noises can be difficult to diagnose from cyberspace. What you are experiencing is most likely a failed or failing throwout bearing and an inspection will be required to see what is making the noise. Eventually the transmission will need to be removed and the clutch assembly inspected.
Feb 9, 2009 at 1:28 PM
