2002 BMW 325 CHECK ENGINE LITE ON
HECTOR HERNANDEZ
  • 11 POSTS
Engine Mechanical problem
2002 BMW 325 6 cyl Front Wheel Drive Automatic
ENGINE CODE ARE.. 0313-MISS FIRE DETECTED LOW FUEL LEVEL..0300-CYCLINDER MISFIRED DETECTED..1353-MANUEL CONTROL IGNITION SYSTEM MISFIRE..1349-SYSTEM TO LEAN BANKS.1083-AUX EMISSION CONTROL.1085 THE SAME READING..THESE ARE THE CODES ITS READY AND DESCRIPTIONS..THANK YOU
Apr 23, 2010 at 10:47 AM
DOCHAGERTY
  • 9,606 POSTS
The issue might be resolved with a full tank of gas and clearing the codes. Low fuel can cause mis-firing and lean conditions. If the faults show up again, repost with the results and then we can move towards a successful repair.
Apr 24, 2010 at 4:53 AM
