2002 BMW 325 Backup warning
PDOUTAZ
Computer problem
2002 BMW 325 Two Wheel Drive Automatic 160000 miles
My manual says I should get an audible sound, increasing in frequency, when I am backing up and approaching a barrier, but mine does not sound. I suspect the previous owner had the alarm AUDIO portion turned off, would this be related?
Thanks
Aug 8, 2010 at 10:37 AM
DOCHAGERTY
  • 9,606 POSTS
Related to what? It either has park distance control or it does not.
Aug 8, 2010 at 2:17 PM
PDOUTAZ
Let me clarify - The local dealer tells me the audible portion of the alarm system has been turned off (and can be restored for about a $125.00 fee), therefore I wondered if that same control/feature would effect the park distance control's audio component ?
Aug 8, 2010 at 6:30 PM
DOCHAGERTY
  • 9,606 POSTS
The alarm is not a standard item on the E46 body style, it has to be installed and coded to the car separately, it is not integrated into the park distance control. PDC is a distinct component. Yes it could have been turned off, it may or may not have a factory installed alarm, an easy way to tell is to look inside the roof mounted ultrasonic detector, if there is a module plugged into the wiring harness, then it has a factory installed alarm.
Aug 9, 2010 at 12:54 AM
