2002 325i Air Conditioning Malfunction
GSXR4FG
1st thing..what a great website...bless you for all you do!!
2002 BMW 325i w/60K miles; basic 6 cylinder engine (184 HP).
Airconditioner not holding charge (freon); had it charged twice by two different mechanics and whether I use the airconditioner or not the freon is gone in a day or two.
Both mechanics put a dye into the engine but have not been able to detect a leak in the system.
Not a repeat problem that I am aware of; bought it used last fall.
Thank you for your help!!
Jun 11, 2007 at 4:37 AM
BRUCE HUNT
  • 3,754 POSTS
Basically the dye will locate leaks on the components of the A/C system but a leak of that proportion has to be blowing out VERY quickly. It is something that is leaking so fast that I would almost suspect that someone could hear it; not me as my hearing is terrible. Have you checked thoroughly the system to include that radiator that cools the A/C system?
Jun 11, 2007 at 4:52 AM
GSXR4FG
Mr Bruce, thank you for your prompt reply! I have noticed the system laboring differently than usual. The question I have is, if I noticed this, then a cert. mechanic should be able to pick it up also?
Additionally, if the radiator is errant would the interior temp cooling gauge rise?
Thank you once again!
Jun 11, 2007 at 5:15 AM
