2002 BMW 325 AC Compressor Cycling
JBEEDO
55,000 miles, 6 cyl engine The air conditioner works fine when it works, but the compressor only comes and goes. Been checked, everything OK - fluids OK, compressor good, but doesn't always stay on. In HOT HOT HOT area, need it to work - any ideas?
Jul 3, 2007 at 5:20 AM
DOCHAGERTY
  • 9,606 POSTS
the IHKA system for climate control in your car can be interrogated with a scan tool.I would begin with faults set in that system and possibly recoding the IHKA.it may require replacement of components.repost with your Email address if this does not help and I will contact you.
Jul 21, 2007 at 9:50 AM
Suggested Repair
Scan the IHKA climate control system for stored faults, consider recoding the IHKA, and replace any failed climate-control components indicated by the scan.
Conversation Summary
The owner of a 2002 BMW 325 says the air conditioner works when engaged but the compressor cycles on and off. Fluids and the compressor have already checked out. The expert recommends scanning the IHKA climate control system for faults, possibly recoding it, and replacing components if needed.
