2001 BMW 325 oil
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
JBISHOPS7
Oil is down a quart every month. The dealer has checked for a leak and found none.
The dealer says the car burning this much oil is "normal"
Is it normal ?
If not , what do I, before the warrwnty runs out.
Mar 30, 2010 at 3:08 AM
DOCHAGERTY
  • 9,606 POSTS
You have an extended warranty thru the dealer, good luck getting them to admit that the oil consumption is abnormal, BMW says 1 quart in 1500 miles is acceptable and it goes higher for the M motors. The fine print might be worth reviewing on that warranty contract mate.
Mar 30, 2010 at 9:49 AM
