2001 BMW 325 Flashing Turn Signal
2001 BMW 325
122,000 MILES • 4 CYL • 2WD • AUTOMATIC
VIPER1ONE
When I turn on the turn signal (left or right) it "sometimes" flashes rapidly for 5 - 10 and slows to a seemingly steady pace. Why?
Feb 10, 2008 at 8:34 AM
DOCHAGERTY
  • CAR REPAIR CONTRIBUTOR
  • 9,603 POSTS
The ground wire in the tail light assemblies is the problem. Remove the connectors and inspect the brown wire and the connection in the tail lamp assemblies. I have repaired these with success and sometimes replacement of the wiring connector or hard wiring the brown ground wire to the ground bus will do the trick, send me your e-mail address in a PM and I will try to talk you through this repair.
Mar 12, 2008 at 7:08 PM
