2001 BMW 325 E brake light on speedometer not working ABS l
2001 BMW 325
DUNTERRE
Electrical problem
2001 BMW 325 6 cyl Two Wheel Drive Automatic
A few days ago had a blowout left rear tire. Now the speedometer dosen't work,the emergency brake light stays on and the ABS warning light is on. I'm thinking maybe a damaged wire harnes but the brake light switch is in the consul i'm not sure about the speedometer sensor. Thanks for any help you can give
Nov 21, 2008 at 8:13 AM
DOCHAGERTY
  • 9,606 POSTS
Possibly you have a cut sensor harness. An inspection is in order.
Nov 22, 2008 at 9:56 AM
