2001 BMW 325 Computer & Engine
77,500 MILES • V8 • 2WD • AUTOMATIC
JSC-MLT
I have a BMW 325 I SE (2001) Auto & inspection has expired by -3455 miles.
Suddenly the following problems started:
1. While driving, CD, GPS, Computer Management & radio which are all build in together is shutting down!
2. Engine start fine on first attempt in the morning & drive perfect. However the second times I start the engine say after stopping for a period of 15 minutes, the engine will stall!
Am I having these problems because I did not re-set the inspection meter to zero?
Thank You.
Joseph
Jun 8, 2008 at 12:05 AM
DOCHAGERTY
  • 9,606 POSTS
No Joseph, the resetting would not have anything to do with it. The issues you are having have set faults and they can be read out with the BMW proprietary software, make an appointment to do so and repost with your findings.
Jun 8, 2008 at 12:59 AM
