2001 BMW 325 clutch problems
51,000 MILES • 6 CYL • 2WD • MANUAL
DAOERO
some how the hydrolic oil drained out of theclutch........it happened very sudden............i noticed some smoke so i pulled over and it was the oil on the engine smokeing..........after i realized what was going on i tried to but the car back in ger and was unable.............now when i push in the clutch i can hear the pump running dry...........my proplem now is how to find the master and slave cylinders to see what i need to fix................any help with the location of or easy removel would be greatly aprecciated........thanx
Apr 10, 2008 at 4:19 AM
DOCHAGERTY
  • 9,606 POSTS
Replacement of the clutch slave cylinder sounds like the solution to your problem.
Apr 10, 2008 at 8:48 AM
