1995 BMW 325 Replace radiator
160,000 MILES • 6 CYL • 2WD • MANUAL
GAUDIOT
The radiator has a pinhole leak (more or less plugged by its own corrosion which gives me some time to fix it). What steps do I follow to replace the radiator?
Oct 31, 2009 at 8:57 AM
DOCHAGERTY
  • 9,606 POSTS
Replacement of the radiator is straightforward. Drain the coolant, remove the fan and shroud, loosen the clamps for the hoses, release the hold down clamps take loose the hoses and out it comes.
Oct 31, 2009 at 3:56 PM
