1995 BMW 325 leaking coolant
KKARPUK
Engine Cooling problem
1995 BMW 325 Manual
had thermostat replace , along with rad. head gasket check , cylinder head all okay after pressure checked. but not sure if still leaking found some coolant outside on ground dont really no if it was mine .drove it again parked check 1 hour later no leak .when would it leak if it is? what to do please
Sep 29, 2009 at 2:40 PM
DOCHAGERTY
  • 9,606 POSTS
Clean the coolant spills, run until operating temperature is reached, inspect for leaks. It is most likely to leak if left to cool after the above is tried.
Sep 29, 2009 at 2:47 PM
