1995 BMW 325 Fuel Issues
KNOTURS21
Engine Mechanical problem
1995 BMW 325 6 cyl Four Wheel Drive Automatic
I have a 95 325i BMW. Which I am having issues wit it stalling and now not starting. I have already replaced the fuel pump as well as the fuel pump relay as well as the main relay, i need to know what might be the other possibilities as to why I still am not getting any power.. I have checked the fusees and they all work so what is the next step or the next thing i should check. Also, yes I do get a spark from the spark plugs.. And there is gas in the vehicle as well.. Might I mention i have replaced the crank shaft on it as well. Need help please advise..
Jun 28, 2008 at 4:03 PM
DOCHAGERTY
  • 9,606 POSTS
Have you checked the fuel pressure and delivery yet? If you have spark then fuel would be next on the list of things to check.
Jun 28, 2008 at 11:12 PM
