1995 BMW 325 cooling system light
1995 BMW 325
167,000 MILES • 6 CYL • 2WD • MANUAL
THE3BEEZ
I have recently had to replace the thermostat because it was sticking, causing my gauge to register hot. I also had my ac belt changed and my cooling system sensor changed. They said that it held good pressure and that it runs good. Now, all of a sudden my cooling system light that says check owners manual has come back on. What should I do next? They said nothing is seriously wrong but I want that light off.
Dec 29, 2008 at 3:35 AM
DOCHAGERTY
  • 9,606 POSTS
If the low coolant warning is on and the coolant is not low then the coolant level sensor is faulty and should be replaced.
Dec 29, 2008 at 3:51 AM
THE3BEEZ
The light doesn't say it is low, it says check coolant system see owners manual. Is this what you mean?
Dec 29, 2008 at 8:50 AM
DOCHAGERTY
  • 9,606 POSTS
Yes, the coolant level switch is bad and needs replacement.
Dec 29, 2008 at 10:49 AM
