1994 BMW 325 Window regulator
1994 BMW 325
129,000 MILES • 6 CYL • 2WD • MANUAL
MDWGOLF
How do I replace my right front window motor. It also seems that the window lift mechanism is separated from the motor.
Aug 30, 2009 at 1:03 PM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model the 325i or 325is………also what is your engine size in liter and you do have a 4 door?
Aug 30, 2009 at 1:09 PM
DOCHAGERTY
  • 9,606 POSTS
The factory option was to use rivets to secure the window regulator to the door, and then the window motor is screwed to the frame of the window regulator. If there are broken parts then you can get a great exploded view at Realoem.com for part identification and pricing too. Does this help?
Aug 30, 2009 at 1:30 PM
