1994 BMW 325 window motor
25,000 MILES • 6 CYL • AWD • AUTOMATIC
DARDMQ
how do you install the motor in the window
Dec 30, 2009 at 11:46 AM
IMPALASS
  • 3,112 POSTS
Hello
To better assist you is your model the 325i or 325is and what is the engine size in liter.
Dec 30, 2009 at 12:34 PM
DOCHAGERTY
  • 9,606 POSTS
I think the question from my associate should be, "is it a two door or a four door, front or rear, left or right? Engine size is not significant. E36 require drilling of rivets to remove the window regulator/motor and it might also be a good idea to let us know what the problem is too.
Dec 31, 2009 at 12:58 AM
IMPALASS
  • 3,112 POSTS
Hello - We haven't heard back from you. Hope all is well. I wanted to know if your engine size to check the TSBs etc to see if there was anything else we could provide for assistance. As you see, Dr Hagerty and I are eager to assist you and working together on this. As the Doc stated, unless the motor has been changed before it will require drilling rivets etc. Also, as he stated what is wrong with the window, or what is it doing. For now I will go ahead and provide you with the removal/installation of the motor........ Between the Doc and I we will be glad to assist if this doesn't fix your problem. REMOVAL & INSTALLATION WINDOW (4-DOOR) Removal & Installation Remove door trim panel. Lower window about 12" (30 cm). Disconnect window motor electrical connector. Push clips aside. Hold door window and disconnect window lift arms. See Fig. 1 . Twist and lift out door window. To install, reverse removal procedure. Fig. 1: Disconnecting Window Lift Arms Courtesy of BMW OF NORTH AMERICA, INC.
https://images.2carpros.com/forum/automotive_pictures/248015_1_191.jpg
WINDOW MOTOR Removal 1. On 4-door models, remove window. See WINDOW. On 2-door and convertible models, clamp door window at raised position using wooden wedges. On all models, remove door or side panel. 2. Remove screw from inside door handle. See Fig. 2 . Remove door handle. Remove bolts and grind off rivets (as necessary). Remove window motor.
https://images.2carpros.com/forum/automotive_pictures/248015_2_126.jpg
See Fig. 3 .
https://images.2carpros.com/forum/automotive_pictures/248015_3_90.jpg
Installation To install, reverse removal procedure. Replace rivets with bolts, washers and nuts.
Jan 1, 2010 at 3:36 AM
IMPALASS
  • 3,112 POSTS
Hello Also, forgot to put this on too. It looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Picture1_109.jpg
Jan 1, 2010 at 3:39 AM
