1994 BMW 325 throttle body
194,000 MILES • 6 CYL • 2WD • MANUAL
RJBAUERIUPUI
  • 14 POSTS
I am having with the throttle body not wanting to come to a rest on the idle adjustment screw. I have cleaned all mechinisims of grease and sand. Do I need to lube the springs or adjust the tension on the cable. If adjust, to I increase the tension or loosen.
Dec 1, 2009 at 11:08 AM
DOCHAGERTY
  • 9,606 POSTS
You might want to consider replacement of the throttle body, I would.
Dec 6, 2009 at 10:29 AM
