1994 BMW 325 speedometer cluster
200,000 MILES • 6 CYL • 2WD • MANUAL
VERYSWIFT24
My speedometer cluster has started going out off & on... speed, rpm, fuel, temp... display, seems like whenever i use my air conditioning more, i've been told i need a new cluster but dont wanna buy one unless thats really the problem? HeLp?
Mar 6, 2008 at 6:46 AM
DOCHAGERTY
  • 9,606 POSTS
there there now, it'll be all right. if the cluster is failing or has issues, then replacement is the solution. if you try using another one from another car the manipulation dot will come on in the odometer field. good luck and don't be afraid!
Mar 9, 2008 at 4:19 AM
