What repair manual do you have? The power wire to the fuel pump is a green wire with a purple stripe and it goes from the fuel pump relay directly to the fuel pump. If you don't have power at the fuel pump but you do have power at the fuel pump relay, then it is an open, not a short. That wire runs through the body harness and has no interruptions. I would consider inspecting the body harness for damage. Check for continuity at both ends of that wire. Consider a temporary jumper from the relay to the pump to be sure the issue is in the harness. Lastly, I recommend the manual from Bentley publications for your car, they can be obtained from Amazon. Com
SPONSORED LINKS
Saturday, June 28th, 2008 AT 8:42 PM
