I have an e36 that I am replacing the clutch on. I forgot to mount the rubber dampener before installing The transmission. The chilton's manual shows the bolts alternating direction around the dampener. I cannot do this with the trans installed, lacks clearence. 1. Can I mount the dampener with the 6 bolts all facing the same direction? 2. Will removing the rear shaft nut allow me to remove the flange at the rear of the transmission?
Sep 28, 2009 at 7:05 PM
