1994 BMW 325 A couple repair questions
120,000 MILES • 6 CYL • 2WD • MANUAL
GROOSAM
  • 15 POSTS
Recently i noticed that my driver side window would not close and seal properly. I works fine until it reaches the weather stripping then reverse about an inch. on rainy days i have to slowly raise the window until there is a small seal.
Another question was on the brakes. They only seem to squeek when they feel like it, there is no consistency. I heard from a guy at a auto-parts store that with older bmw's and vw's changing that flushing the brake fluid and changing it before it is needed helps. The last time I had the car checked out the brakes were at 90% so i'm not sure that's the problem.
Oct 19, 2008 at 2:01 PM
DOCHAGERTY
  • 9,606 POSTS
The window issue is in need of a new door switch and the brake issue is an annoyance but not a safety issue. A brake fluid flush wont change anything as far as the noise.
Oct 20, 2008 at 12:45 PM
