1993 BMW 325 while driving all the lights in the car comes
183,456 MILES • V8 • 2WD • AUTOMATIC
JOANNA2009
while driving all the lights in the car will come on for 2seconds and turn right back off.. every once in a while this happens. i dont know what the problem is.
Jan 6, 2009 at 11:42 AM
DOCHAGERTY
  • 9,606 POSTS
Do you mean the instrument cluster lights? If so there is a possibility the battery cables or a ground cable is a bit loose, I call it a voltage excursion and it is distracting even if harmless. Check the battery and the charging system and repost if more help is needed.
Jan 6, 2009 at 12:05 PM
JOANNA2009
you know.. when you first turn on a car, all the lights will come on then 2 seconds later, the light will go off but in this case while i am driving all my lights will suddenly comes on and like 2 seconds later then goes off. it happens once in a while when i am driving. i am thinking maybe the wires are touching each other somewhere.
Jan 6, 2009 at 1:55 PM
DOCHAGERTY
  • 9,606 POSTS
This could be a comfort relay chattering on its contact or a intermittant connector, intermittant issues can be very difficult to pinpoint and I usually start with the basics and try to eliminate what it isn't, good luck with it.
Jan 7, 2009 at 2:10 AM
