1993 BMW 325 Transmission Light.
77,170 MILES • 6 CYL • 2WD • AUTOMATIC
BM DUBYA
  • 8 POSTS
My car is fine for about 10 min. then the check engine and the gear light come on and my RPM's go up slightly. I am not sure what they're called, but I replaced the components that are accessible when you remove the oil pan (where all the sensors are located). And now my car wont even shift?! And the original problem continues. What can I do?
Sep 6, 2010 at 12:54 PM
DOCHAGERTY
  • 9,606 POSTS
You have opened a can of worms. The parts you replaced were replaced for what reason? What are the parts, do you have the part numbers?
Sep 7, 2010 at 4:09 AM
BM DUBYA
  • 8 POSTS
I replaced the hydraulic components that are accessible when you remove the oil pan, I replaced them because nothing else had helped. I'm kind of on a guess and hope situation.. sadly.
Sep 9, 2010 at 12:17 PM
