1993 BMW 325 leak
1993 BMW 325
170,000 MILES • 6 CYL • 2WD • MANUAL
MATT10
the car leaks water near the fan blade. it caused one of the blades to rust and break off>
Feb 22, 2009 at 10:09 AM
DOCHAGERTY
  • CAR REPAIR CONTRIBUTOR
  • 9,603 POSTS
A leaking water pump will cause this, has it ever been replaced? They do have a fairly short lifespan, maybe 5-7 years on average.
Feb 22, 2009 at 10:12 AM
MATT10
[quote:36bca44d84="Dr. Hagerty"]A leaking water pump will cause this, has it ever been replaced? They do have a fairly short lifespan, maybe 5-7 years on average.[/quote:36bca44d84]
thank you i was wondering however if it could be a head gasget that could be leaking.. since it is leaking right by the fan blade? or if you are pretty sure it is a water pump...
thank you concers
matt
Feb 22, 2009 at 10:20 AM
DOCHAGERTY
  • 9,603 POSTS
Matt, if you pressure test the cooling system it will show the leak and I like to start with the easy stuff first, if the water pump is bad, it will be a fairly east fix. Sound OK to you mate? ♥
Feb 22, 2009 at 10:24 AM
MATT10
i have another questions are audi a4's good with 150000 miles on it.. would it be reliable and a good car
Feb 22, 2009 at 7:26 PM
DOCHAGERTY
  • 9,603 POSTS
What year is the Audi? Yes the A4 is a good car, unfortunately, I dont have much working experience with them.
Feb 22, 2009 at 7:36 PM
