1993 BMW 325 INTAKE GASKET
GUESSDYJ
  • 1993 BMW 325
1993 BMW 325
When I do a cold start my car is idling rough, only when I do a cold start. Could this be caused by the intake gasket. I just found out my spark plugs are very worn. Could it be the spark plugs. If it were the intake gasket when it only do this during a cold start?
Thursday, November 20th, 2008 AT 11:58 PM
DOCHAGERTY
  • 9,601 POSTS
Try replacing the spark plugs and see if that helps. Removing the manifold without knowing for sure there is a leak is a questionable practice. Poor idle quality when cold is possibly due to other factors such as deposits on the valves or poor injector spray patterns. Try an injector cleaning agent in the fuel before you resort to taking off the manifold.
Friday, November 21st, 2008 AT 12:27 AM
