1993 BMW 325 dies sporadically
18,000 MILES • 6 CYL • 2WD • MANUAL
MW1952
Hello- My BMW will sporadically die. It seems to be temperature related because if left to cool, it will restart. We have replaced the crankshaft sensor and the crankshaft dampening wheel. The error code points to the crankshaft sensor, but because this car is older, it is probably not accurate. Please advise as to what sensors you recommend I should replace. Thanks, Mike
Mar 21, 2010 at 7:44 AM
DOCHAGERTY
  • 9,606 POSTS
How about cleaning the idle control valve and be sure it is working. And the throttle plate too. Look for vacuum leaks while you are in there.
Mar 23, 2010 at 2:36 PM
