1993 BMW 325 CrankShaft Sensor
159,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRWILLIAMSIII
93 BMW 325i, Inline V6 engine
The car will not turn over. It revs when you turn the key
Starter Fluid test did not work, seems to be no spark.
I checked the following items Good:
Fuel pump/ filter
starter
alternator
battery
all lines
oil
Plug/ Wires
I was told I needed to replace the Crank-Shaft Positioning Sensor, I need to know how to replace this sensor and another option if this is not the problem.
Sep 20, 2010 at 6:06 AM
  • 75,988 POSTS
Hi grwilliamsiii@gmail.com, Welcome to 2carpros and TY for the donation Service and Repair
https://images.2carpros.com/forum/automotive_pictures/12900_b1_11.gif
REMOVE AND INSTALL
https://images.2carpros.com/forum/automotive_pictures/12900_b2_7.gif
Unscrew oil pipe from Variable Camshaft Control (VANOS ) control unit. Unscrew bolts. Remove ground tape (1) and suspension lug.
https://images.2carpros.com/forum/automotive_pictures/12900_b3_7.gif
Remove impulse sensor.
https://images.2carpros.com/forum/automotive_pictures/12900_b4_2.gif
Remove electric lead duct.
https://images.2carpros.com/forum/automotive_pictures/12900_b5_3.gif
Mark plug (3) on wire harness and disconnect it. Reinstall in reverse order. NOTE: When reinstalling oil pipe for VANOS control unit, check seals and replace if necessary. Ensure that the lead from the impulse sensor does not contact the water pump drive gear after assembly.
Sep 20, 2010 at 11:31 AM
